Any suggestions on repainting belly pan? Previous owner painted yellow, lookijg to paint back to original look. Were they black or purple? Stickers on hood missing also.
What can I use to strip paint from plastic?
i wld try laquer thinner or brake klean n if that dont work theres this stuff called zip strip... i wld put it on a rag and put it on there and let it soak in and if that dont work try to soaking rags n put plastic over it so air can not get to it and over time it should soften up and u can remove it... actually before u buy anything i wld read the label because all of the products i just listed are pretty hot chemicals and cld distort plastic, or atleast maybe try it in a small spot
