So after cleaning the carbs very well I put them back in the machine. I pulled it over about four times it fired up and idled\ran smoothly at about 2,500 rpm it was very responsive. I could hear nor see any problems untill I pulled it out of the garage to ride it. Once I had it out I had plan to let it run for a sec but it started to bogg out so I went to give it throtle as soon as I gave any gas it stalled out. So I took a look under the hood to see if I could diagnose the issue. I noticed that there was'nt any gas to the second carb the first carbs line was full. I pulled it over a few more times watching the fuel lines the fuel would rise up half way and then drain back towards the fuel pump and sit about an inch or two from the pump?
