when I give my wildcat alot of throttle it makes a couple of hollow clunks. sounds like it is coming from the backend. it only does it when I goose it.
could be ur cog bearings
well, reverse went out today and upon opening the chain case i found the chain tensioner broke. it would work in forward becuase the gear direction would tighten the chain, but in reverse it goes slack. we will see.
The one thing I would change as well is the auto tensioner! Remove it and the mechanical tensioner bolt and outer nut will thread in and work better!
sounds good, let me get this straight. toss the ratchet arm, spring and back plate and then reinstall the nut on the bolt which held the above. is that correct?
