1 - 1 of 1 Posts
Hello I have put a 95 vmax 600 motor in a small sandrail and I keep fowling plugs to the point that it only gets full power for maybe 30 minutes then fowls the plugs, I think its the tors system causing the problem. I have put the blk a wht wires together to eliminate it but it still seems to be causing problems. I have the throttel and the oil injection cables both pulling at the same rate. ? is that the problem or do I need to change something else. Any help in this matter would be a great help. Thank you in advance
1 - 1 of 1 Posts
