Checking out my cousins sled. Its a 95 indy 500 with reverse. Well when you drive it to get it into the shop it would clunk like it was jumping a gear or something. Checked out and found belt was missing a whole bunch of ribs. Put a different belt on and now it dont do it unless you get into it and it rumbles and vibrates the whole sled. Checked chain tension and is ok no teeth broke. Checked track and dont see broke lugs on track and drive wheels look fine. Kinda lost now. Only things are what is the play in the track supposed to be at? and also how much should you be able to move the track before the gears start moving? it moves like 2 inches versus less the a inch on his z 440.
Any help appreciated i tried to explain everything thanks
