ride till your broke
another triple problem.
after figuring out a coolant flow problem, took her for a blast
around yard. the secondary clutch wasnt working, i have another
spare one, havent switched yet.
but on way home started backfiring thru exhaust,
cleaned plugs, took back out, had no power.
checked & its firing on 3 cylinders.
did compression test,wot & pulled till it stopped going up.
has 90psi across the board. very low.
so basicly in looking at rings and gaskets??:dunno:
going noew to pull secondary from parts sled now.
Discussion Starter · #2 ·
update; put oil in cylinders & recheck compression.
same as before-90psi each cylinder.
also went to take secondary off parts sled & theres a bolt
holding it on in center, mine has no bolt, if you look in
the hole, can see keyway and threaded hole but no bolt.
so ive been riding this with no holdown bolt.
secondary wont budge on either sled.
cant believe mine didnt fall off.
secondary slid right off when bolt was removed on parts sled.
so u guys think a little heat would help on my
sled, still cant believe mine wont budge with a bolt missing.
that was never in since i got it!!:eek:
having a great season with this sled. haha
took top end apart, all looks good.
then did a compression test on my rev, only 90psi.
so i borrowed another tester and did again.
150psi.:eek:
so i had a bad compression tester all along!!!
so ordering gaskets thurs, and putting back together.:D
needless to say with cooling probs & now this, it might
get ridden before valentines day.:cheeky4:
