I own a pair of 94 Prowler 2ups 440 EFI. On a few seperate occansions both machines have suddenly quit when running about half throttle after being warmed up. In each case I let them sit far a few minutes and they restart and run fine again. Both have GOOD batteries so that's not the problem. Has anyone else experienced anything like this? My mechanic suggested I clean the injectors and see if that helps.
Try that, also check to see if you have alot of play in the pivot point on your throttle lever, if so you might need new washers for the throttle safety. Did they do it at a certain time? Like standing up or any other particular time?
