Ok seems easy enough but broke my starter cord and thought I will just undo housing pull it out and fix it...but ran into an immediate snag with one of the housing bolts being blocked by frame bar...do I need to actually lift up the motor to access the bolt to remove the housing..cannot life be simple?:mad:
Discussion Starter #2
Ok answered my own question....ended up having to loosen up one side of the engine mounts and while one person lifted on the engine the other got the bolt out and the housing off....that bolt will not be going back in as this was a pain in the butt...there is also a belt inside so ya need easy access to that as well just in case....road some bumpy trails ooh my aching back!!!!!
Rick
lol same with mine. that belt is for your water pump.
