Check that the key switch is not shorting or that either of the relays (ECU power or fuel pump) are not sticking. There are also parts called Posistors that tell certain lights (Rail pressure,oil level, temp warning) to turn off after start up diagnostic. These can also be a problem and are easily replaced at little cost.
