1 - 1 of 1 Posts
I have a 94 MXZ with the 470 LC. The thing starts really hard all the time and takes forever to warm up. If it is not completely warmed up the idle starts dropping down and when you go to give it a little throttle it boggs down and stalls unless you get to the primer in time. It has fairly low miles, a new fuel pump (didn't help the problem), and the carbs have been adjusted by a dealer. Any ideas?? Should I check the compression though the thing pulls like it has a ton?
Old Indy
1 - 1 of 1 Posts
