I recently took my indy in to get it ready for the winter and i took the pipe off to patch a small hole and noticed there was a lot of oil in it and leaking out of hole in pipe it still ran like top with out too much smoke do i need to adjudt oil pump or replace it?
I wouldnt worry about it, its obviously getting oil, which is a good thing. I would certainly check the oil pump setting, there is a line on the oil pump body and a line on the oil pump lever, they should be lined up at idle (or with the engine off)
other than that, a 2 stroker burns oil to live, so oil in the exhaust is normal.
excellent thats what I was hoping!! The marks match so its bussiness as usual and thats a good thing! need a new sled just not this minute ha ha
