I found that two bolts (same spot on the sled, both sides) somehow came out. Didn't know how to line up the holes on the body to the bolt holes. Thought it would help to disconnect the holes further up the sled so I took those two out. Then disconnected the spring and the rear schock. Nothing is helping! Seems to get worse! Do I have to disconnect the whole suspension and start over?
Take the springs out behind the front idler wheel. Just pull up and bring them out over top of the wheel. The rod will hit the ground.
Put the 2 front bolts in first. Then the 2 back ones. It takes 2 people to do this. Most of the time. Sometimes you'll luck out but most likely you'll need 2 people.
MarcusSport440
do what xcrider22 said. but it won't line up perfect. your gonna have to lift the back of the sled up a bit. then wiggle the suspension around. your gonna want someone else to do it with.
