starts hard if sits long idles ok after you get it started . Starts missing and surging almost immediately when you try to ride it then soon pulls down and dies and won't restart. Appears to be running out of gas. Pulled line up out of tank. Nothing on end. Is their supposed to be check valve on this 94. Also if this don't fix , how do you check out the fuel surge pump.
I would start with replacing the fuel lines and looking for anything kinked. There is a tube in the tank with a pick up strainer/filter and that may need cleaned/replaced. Fish it out with a coat hanger and examine it.
