Hi all new to the forum just looking for some advise. So i aquired a WC..
Found the grounds to the stator were disconnected, reconnected and she fired first pull, however only on one Cylinder. PTO running fine. I swapped injectors, same thing so im thinking its the signal wire to that MAG injector. From what ive read the wiring on these sleds is a issue. I can see by the harness that runs under the jackshaft its a mess. Doesnt look really that bad, but i guess these AC's are picky and they ran this harness like idiots.
I downloaded a manual, and was able to send 12V through the ECU plug and heard both injectors click so i assume its the Timing sensor on the magneto. I tested the Ohms and that and it was within spec. One thing i saw was there is a white and a orange coming from that sensor going into the main harness. I found a small crack in the wire. Hoping that is it, but i have to go home and rip the harness out i dont want to do this twice. Am i heading the the right direction.
RJ Gleason pelase jump in. I see your the WC expert. Any advise would be great.
I cant find a legit Wiring diagram so i dont know how the orange/white wires turn into the injector signal wires. Where do they go in the Loom?
