im looking for a set of pipes because the current pipes had pinholes when i bought it and there slightly larger after riding the first time out so now the leaks are a little more intense. also my speedo doesnt work and im not of the reason the cable is connected and i cant find anything broken. any help would be apreciated
Fool Injected
Can't help you with the pipes but the speedo issue is most likely caused by a broken adapter cable that goes between the speedo drive and the drive shaft .. If you remove the drive to check it out look at that side bearing as well because it will cause these problems in the first place.
