I tore apart the driveshaft bearings both with catastrophic failure.
I want to reassemble but want to find an exploded view.
Second the pressed flanges for the speedo side are not parallel with the flange base and I'm wondering about their orientation.
Thx Gord
The speedo side should be one with a set screw. So you put it all together without tightening the set screw. Make sure the bearing is centered simply by rotating the track a few times. Then tighten the set screw.
On Cats the bearing is locked down at flush with the end of shaft.
Both 3 bolt plates are on the inside of tunnel
