I have a burnt piston and cylinder on my 95 RXL 650. I see a 92 top end complete with cylinders, pistons, heads, water pump,....pretty much everything. Can I mix and match the cylinders,......are they exact? pistons?
Please help.
Thanks prox,....yeah,...the whole thing,.....jugs,...pistons, heads, water pump,.....n water lines. Its all bolted together yet with exception of the pistons n pins. But my main concern was can I just replace the one piston n jug? Minor porting,.....piston weight,.....anything that changed that might screw it up?
i recamend puttin on all three jugs, i know they didnt change the base so the jugs will fit, as far as porting you would be better off just using all the same year top end, just in case.
