Hey guys, I applied some threebond to my crankcase halves tonight, put them together, but when i went to tighten the bolts down my manual only had torque specs for 8 and 10 mm bolts, but mine seem to be 12mm.
Does anyone know the torque specs for a 1991 indy classic with 12mm bolts?
crankcase, cylinder base, and cylinder head specs would be greatly appreciated.
Thanks in advance!
- seth
thanx for the speedy response Ken, appreciated!
Anyone know if it would be ok if i just torqued my 12mm bolts to the specs for 10mm for the crankcase?
seth, the general torque for a 12mm is 40. you sure those are 12s. 40 seems like an awful lot. I think I would go with the 23-25 or maybe even bump it to 28
Hey ken, If the mm size they are referring to is the size of the head on the bolt then they are 12mm. I use a 12mm wrench to tighten them. OR are they referring to something else? i am new at this..........
thanks,
Seth
