How do you set the polaris chokes ? is there a distance that should pull up? The top end on my sled bogging down . I think its the chokes . HELP ! :dunno:
mainly make sure they are fully seated. there should be a little play in the lever that activates them... to ajust them loosen the nut on the cable that goes into each carb and then turn that bolt in or out to adjust it
as long as they are both bottomed out they won't affect it during riding. excess slop may make it harder to start but if it starts fine then you will have to looke elsewhere for diagnosing the bogging. when was last the last times the carbs were thouroughly cleaned? that could help
