1 - 10 of 10 Posts
Welcome
Have you started with just removing the plug cap and cut 1/4" off wire and screw back on
Have you unhooked the key switch and kill? Bypass both?
will try that tonight. probably the only thing haven't done yet. will just unhooking key and kill switch bypass them? thanks.
well that didn't work for me.. stator checks out. coil checks out..my key switch continuity check is backwards then what I've heard it's suppose to be. so I'll get a switch and try that?
Discussion Starter #8
I was thinking unplugging was bypassing. how do you bypass? jump the two wires on each switch together? thanks
1 - 10 of 10 Posts
