Hi, I recently purchased an 89 Jag AFS 440 with reverse. It runs good however it will not go into forward gear. Reverse and neutral are fine but will no go into forward gear. Any ideas?
I have also been looking for a service manual so I can do a complete restore on it, anyone know where I can get one?
Seus
The linkage could have to be adjusted or the spring that pushes your reverse gear in and out could be worn out, that happened to me.
There should be a plug inside the tunnel to drain the chain case.
Open it up and have a look.
The lower gear is messed up.
