N E one know the cylinder head torque specs for an 88 exciter 570? Help with this would be MUCH appreciated. Thanks
Royboy,
According to my Clymer book, and having just recently replaced a head gasket on my Exciter, the torque settings are as follows:
It is a two step process. The first stage you torque both the nuts and bolts to 14 ft-lbs in a crisscross pattern. Then tighten the cylinder head nuts to 24 ft-lbs and the the head bolts to 20 ft-lbs, also using the crisscross pattern.
Generally after I torque the head I let it sit for about 8 hours, then recheck the torque because the gasket will have taken a set. After warming up the engine and bringing it to operating temperture I will shut it down and recheck the torque for the last time. I have never had an additional leaking problem by following this setup.
Good Luck
