I have no idea what is wrong with my sled... here is what it is doing.....when I am ready to ride I start it up and let it warm up for about 5 min. than I go out and ride. No more than five minutes after riding the sled begins to bog down past about half throttle, also there is a lot of backfiring and smoke coming out of the exhaust, I can barely get any speed out of it to make it move. when I lift the track up off the ground and hit the throttle it acts as though nothing is wrong but as soo as i get back on and ride the same problem occurs again. If anyone has any suggestion on how to fix this it would be greatly appreciated.
Remove the plugs and check them out. They should be dry and brown color. If they're wet, the carbs have issues, either needing cleaning, etc.
I forgot to mention that when i pull the plugs and looks at them one side is always the right color but the other side is very wet and black
The wet black side is the problem carburetor. Take it off and clean it. Set the air bleed screw to 1 turn out from seated. That should get you going again.
It fouled that plug, but since it's one carb, try going one step hotter on the problem side. If it takes BR9ES plugs, try a BR8ES on the bad side.
I had a similiar problem with an old 72 Arctic Cat Cheetah, started and ran fine, after a good run, bog down and eventually die, had to sit a while to get going again. Also a single carb, with one side getting fouled worse than the other. Turned out to be a bad coil on one side, got hot, went dead. A friend of mine bought it from me, put 2 new coils in, and it ran like a champ, no more dying. I would try a coil on the fouling side, or swap your coils side to side to see if the fouling switches sides, to verify a bad coil.
