sled ran last year parked it now wont start no spark? replaced cdi box still no spark put tester on wire to coil lights up hit kill switch goes dead so i know kill switch is good, plug cdi to coil turn over no spark put tester in plug end of wire faint power very little please help thanks
you need to run some tests on the stator as well as the other coils in the magneto. easily done on the sled. could also be associated with excessive rust/corrosion on the mag itself or some rodent gnawed wires.
