Picked up used 86 safari. Don't have manual yet. Drive gear box has plug rather than dip stick. How full do I fill and with what type oil? Thanks Ed
is there a # stamp on the cast?
call the skidoo dealer and ask them how much to put in.
I use MAXIMA chain case lube, its about 5 bucks a 16OZ bottle.
HAVE YOU PULLED THE PLUG? MY '89 HAD A DIP STICK ATTACHED TO PLUG,IF NOT ABOUT A PINT SHOULD BE RIGHT
GOOD LUCK
Mine just has a plug with no dip stick. That why I didnt know to what level to fill it to. Thanks!
Is there another plug on the side cover of the chaincase, lower than the fill tube? If memory serves, some of the sleds had a plug that you pulled out, filled thru the fill tube until the lube started running out of the plug hole. Replace the plug again after filling, of course :)
I check my case every 300 mi or so. It only takes a second, and it let me know my shaft seal was leaking last year! I use Klotz synthetic, much less wear!
