1 - 1 of 1 Posts
hello its paul i put a cleaned carb on my sled i pull it over it takes right off i cant bring it the rpms down the throttel is backed off totaly i squeeze the throttel it bogs out i turn the only screw closed it dies out i open it a little im talking 1/8 turn it takes right off i spray starting fluid around the intake manifold nothing happens i spray pb blaster around the intakes nothing happens seems there no leakes i do notice the butterfly plate has a small notch out of it when closed air might be getting by theres a hole in the plate from factory so i was gonna cover it with tape to see if that butter fly is letting to much air by the choke valve isnt leaking by it closes in side the bowl that brass pickup tube i blew in to check the valve to see if it leakes by it doesnt any thoughts Thanks
1 - 1 of 1 Posts
