So my sled is running way too rich after I took it out. I adjusted the needle on the sliders, bottomed out the "choke" plungers, worked great for about 15 minutes, then went back to bogging itself down. I'd say to re-jet it, but if it was running good for a bit? If anyone can help, it would be appreciated.
Stock 82 Deere Liquifire 440, Mikuni carbs, Kawasaki engine.
I took off the carbs, took them right apart, let the bowls soak in carb clean, let the bodies soak in gas to remove all the build up on the outside, hit them with a tooth brush, dipped them in clean gas, sprayed the insides with carb clean, blew them out with air several times, cleaned the jets, needle and seat ect. Floats move free, all passages are open. Didn't touch any of the adjustment screws aswell.
