i have a 81 jag 4000 it is poping bad and i think backfireing too... i changed the coil and black box.... what could it be?
can you adjust the timing on them or no??? any ideas??? new plugs too.....
Make sure that you don't have plugged jets in your carburetors. If carbs look fine then it could be timing off. If I remeber correctly you can turn the stator plates on the 81 Jags. It could also be a partially sheared key in the flywheel.
The best way to check your timing is with a Strobotic (Xeon) Timing light. A standard timing light can not keep up with the speed of the 2 cycle ignition.
I would recomend tring to find a tech manual for this so you can be accurate with your timing specifications
