I got a free 80 pantera 500 fan cooled that had been sitting for 5 years or so. Cleaned the carbs right away, new plugs, etc. It ran right away, but would not idle at all. Seemed to run better cold. I've had the carbs apart and cleaned about 5 times now. Tried to spray wd-40 around the pto seal, but did not get a reaction. I've heard these are notorious for center seals. Would that cause the plugs to be different colors? I took it on a vintage run last weekend and about 8 miles in, started to loose power. Now, one cylinder is dead. I've accepted that it is likely a crank seal problem from what I've heard from other old cat guys. Sound right?
What special tools do I need to perform this myself? does the clutch and stator have to come off? I've never had a two stroke torn apart before, but I am cheap and would like to do it myself. Not to mention the satisfaction. Also, when I look at the parts picture on denniskirk, I only see two rubber type seals. Are these the outside seals? What does the center seal look like? Is there a center seal? I'm a little confused on that one. Is this a good time to put new rings in? THey seem to be cheap. But, will the pistons even be out of the jugs for this job? Sorry about all the questons.
