Hi i'm afraid i damaged my sled i mixed around 10 liters maybe 11 liters of gas to 250 ml of oil does that sound right .
I did the conversion and it sounds about right. On the English scale, you want 50:1 and that is 16 oz of oil to 5 gallons of gas. If I did it right, 10 liters is about 2.5 Gal. 250 ml is about 8.5 oz, So you would actually be a litter higher in oil, but that will not hurt anything.
Thanks for reply i just got this sled it started good ran good i used it 3 times for about 10 minutes each time then it stalled won't start checked compression 0 psi in pto side not sure what happened
Not sure why you needed to convert to US units. 10/.25 = 40:1 11/.25 = 44:1
thanks for reply took engine apart an pto piston has a hole in it.there is some aluminum from the piston on the cylinder i have honed it and looks ok so i will need a new pistonad all seals
take a look at the carb boots between the engine and the carb. Make sure they are in good condition.
