my intruder wont run. I cant blow through the fuel filter and need to know to replace or if that is normal..
thank you
Certified Mechanic
Replace it. Also do a compression test; should be at minimum 120 psi to run properly, and actually clean the carb, not with add-a-clean like seafoam.
