This is an odd problem. Normally I have it where the sleds are hard to start but once started they are fine. This sled is the opposite when it is cold. Fires right up usually first or second pull. Idles nice and high. Once warmed up though it won't idle at all. It bogs way down and it seems that it is running way rich. I have to hold the throttle open a decent amount and keep feathering it to keep it going. Once down the trails it runs great as long as you keep it about 1/2 throttle.
I already cleaned out the carb but that didn't help any. Also I have the idle screw all the way in. The mixture screw doesn't seem to change anything. The choke seems to work just fine. What else should I be looking for?????
