1 - 17 of 17 Posts
hey I have an ex 440 and it blows pistons about every 100 km. I have done almost everything it could be...except the cdi box. Could someone tell me if it is that or if it could be something else that i might not have checked....and if someone could maybe find a cdi box from that year and tell me about it. Thanx alot for your help
Mikey
What do you mean "blows pistons"? CDI's just provide spark. Blown pistons are usually caused 2 ways: running way too lean, or not enough oil. Are the cylinders OK? If it's just the piston, it's too lean. Re-jet it richer.
the piston is not being blown, it just puts a hole in the center of the piston. Oil injection is known to be good and so is carburation. And it is the stock plugs so it is not those. But i am not quite sure about the timing.
Mikey
You should hear it pinging quite loudly when under acceleration if it's timing. The pinging is pre-ignition, which will eventually burn a hole. What do the plugs look like when you take them out? They should be a dark brown in color. If they are light tan/white it's too lean.
So basically it could be the timing or it is too lean?....i don't really know about the plugs. Its at a friends house right now
thanx
Mikey
Discussion Starter · #9 ·
hey....sorry i haven't replied for a long time...my computer crashed. The guy i bought it from said that the piston goes into a "four corner seizure" The piston seizes up...on the fan side i think. He said that he had a yamaha dealer ship do the seals on the crank....is it possible that air could be seeping in through the crank somehow?
Thanx
Sounds like an air leak somewhere. Do a leakdown test and that will tell you where the air is leaking from.
Discussion Starter · #12 ·
Somebody said that they did this engine with silicone.......is it possible that thats where there is an air leakage
is it one piston blowing each time? is the carb good and clean, and the carb boots not torn or leaking? and crankseals are a big cause, doubt the timing is off unless someone messed with it......
Discussion Starter · #14 ·
ok....i got it alll together.....i hope that it doesn't pop another piston.....how long would it take for it to blow a piston if it is sucking in air somwhere? Would it have already blown a piston if i had it wide open for 4-5 seconds?
Mikey
Maybe not, but check that plug to see how lean it's running. It should be a dark brown, and not a gray or white. If it is, it's still WAY too lean. That way you can fix it before it messes up again.
I have the answer..
True story here....
I burned a hole in about 4 pistons years ago on the same sled. I tried everything until I handed the engine to a dealer and said "fix it". Well he put a new crank in it and did this and that and it ran the best it ever did, until the rest of the sled fell apart.
Long story in full version.
I finally asked why I kept burning out pistons. he asked me if I ever sunk it, I did so I told him about it and he said there was a small amount uf fungus growing on the inside of the mail jet. same side as the burnouts.
Just replace the main jet with a new one. get the same one.
ran strong and great, untill the track fell off.....
1 - 17 of 17 Posts
