Help!!!
The 77 panther 340 started and ran just fine this morning. I removed the Walbro carb, took it apart and cleaned it. Installed it. Now I can't start it.
Here are the vitals...
- Spark on both cylinders
- 140 psi compression both cylinders
- Major flooding of the engine to the point that it will not turn over.
- Good vacuum
When the fuel line is removed from the carb and just a shot of carb cleaner or starting fluid is shot into the carb it still will not fire. I grounded the plugs to the block and turned over the engine and have good blue spark... I let the cylinders dry out... still no start. Screwed the idle screw in all the way, and the main screw in all the way... back each out 1 turn on each try... nothing.
I am very confused about this... IT HAS EVERYTHING IT NEEDS TO RUN!!!! What am I missing?!?!?!?!?!
- Good vacuum
