I recently did a complete restore on a 1977 John Deere Liquifire 440. It was my first one and to be honest I don't know a whole lot, still learning. I completely rebuilt the engine new pistons, gaskets, rings. It seems to run great. My only problem is that it seems to bog taking off, once I get my speed up the engine will open up but it doesn't want to get up and take off out of the hole. Now I was wondering if this would be more of a clutch/spring/weight problem or a carb issue. The only things I did to the carbs and clutch were clean them really well, I also balanced the carbs, but didn't tinker with them at all besides that. I'm not totally sure but I'm thinking I want the clutch to grab a little later so would I want to try a lighter set of weights? Or a new spring? Any feedback is appreciated.
Did you remove the pilot jets and run a wire threw them before cleaning?
How old is your belt? How tight is it? How do the plugs look? How much oil are you using?
Plugs are new, oil is 50:1, belt was old, I suspected it might be that so I switched the belt out with a new one. I didn't touch the jets at all. I'm gonna take it for a spin after work and see if the new belt helps.
