just curious if a set of aaen twin pipes for a 76 skidoo rv fit on my 76 tnt everest.
rednekforevr · Registered Joined Dec 14, 2008 · 4 Posts Discussion Starter • #1 • Jan 12, 2011 just curious if a set of aaen twin pipes for a 76 skidoo rv fit on my 76 tnt everest.
T Thunder101 · Registered Joined Dec 14, 2010 · 5 Posts #2 • Jan 12, 2011 more inportant the port timing of the two engines should be very similar along with port area-size.
7 77Scorpion · Registered Joined Dec 16, 2010 · 142 Posts #3 • Jan 12, 2011 are they the same motor? you will probably have to jet the carbs as well
rednekforevr · Registered Joined Dec 14, 2008 · 4 Posts Discussion Starter • #4 • Jan 13, 2011 the sled originally had a 440 f/c, replaced it with '80 503 from another everest. Not sure hat came in the rv's.
