my 74 440 arctic cat starts good when i prime carb with gas/oil and idles fine,when i take off i go a few hundred feet and it bogs out and dies.i then need to reprime and off i go again for a few hundred feet.any thoughts? the fuel line looks like it is sucking air as well as fuel.could it be the little box that comes from the fuel tank and sends to carb or is it a carb issue? thanks again.
Sounds like you need to clean the carbs and fuel pump! Then replace all the fuel lines including the pick up in the tank!
