hi everyone i am just wondering if someone can give me some advice about my machine i have a 1989 650 polaris indy i just got it be for winter first polaris i have ever owned i had it out last weekend it ran great i went over 20 miles with it at the end of the trip it seemed to bog down i just figured that maybe it would clear itself up but i went to start it yesterday and now it wont go so i checked a few things today i took the boils off and cleaned them out and check for spark all cylinders are firing just wondering what i should do next thanks for your help
My 650 used to foul plugs pretty often which resulted in the sled running like you describe. I finally removed the plug wire ends and replaced them with NGK one-piece ones. When I replaced the ends (they just screw on the wire) I cut about 1/8" off the wire to make sure I had a good contact. Try it, it's not too expensive and could solve your problem :)
hey dan thanks for your advice the only thing is. is that it has lots of spark to all three cylinders and it has n g k plug wires already on it what else do you think it might be thanks again
Sconnie
just try replacing your plugs first.
Trevor
My sled did the same thing last year. Ran great, hit some powder, and it bogs down and runs like crap. New plugs and I was good to go!
hi again iam hoping that it is a fuel problem i drained all of the gas out of the tank today. maybe i got a bad batch of gas i have lots of spark to all cylinders and the plugs are new i also took the line out of the tank and checked the filter inside of the tank i will put new gas in and go from there if that still does not work i would apprieciate some more advice thanks again jonaldo
