Hello,
I am trying to see if anyone has done a 600 triple swap into a 91 indy 500? Im looking to see if the base plate bolts will be the same and will te belt and clutch remain the same. Also as for fuel will stock fuel pump move enough gas to work or must i upgrade to a dual pump? Any input would be great. Thanks.
Speed Consultant
You will need the motor plates for the 600 or 650. The 500 motor plate won't work. Should be a pretty easy transplant. You will need to get a tripple fuel pump and different exhaust but other then that should be no problem. Riley
