my sled zl 600 efi 2001, has a engine bog on low end. If I hit the gas all the way, it will stall. If I go about half its ok. I've changed the plugs and put new gas. The carb tunnels are clean. What should I check?
did u check
is it running on both cylinders for sure
when u start it
feel if both exhaust ports seem the same temps
just b careful
i think next i would check fuel pick up
my 00 efi doesnt have a f ilter
just a screen onthe pick up in the bottom of the tank
be real careful taking the pump out of the tank
i have been told they are expensive
just fyi
electronics can be intimdating
troubleshoot as if it were a standard engine
i have 5800 miles on my efi
i blew a f lywheel apart
and sheared a flywheel key
other than that
electronics have been flawless
one time i ran it out of fuel
what a chore to get it re primed
best starting sled i ever had
efi troubles
I'm guessing that theres some thing wrong with the fuel delivery. Ive heard of this same thing happening with carbs that are jetted too rich.
Check and replace your throttle seats before you go too deep. If the tang is broken or worn it will act like that. Its only a three dollar part but Ive seen guys spend hundreds at the cat dealer before they brought it to me.
I'm new to this forum butm I know about the kill switch. YES, That is probably your problem. Disconnect it right under your handle bar pad. Your problem should stop. I don't know why this works or what has gone bad but I had the same problem with my 98 ZR600 EFI When I disconnected the kill switch it ran fine.
