swapping out motors after some serious bearing issues on my 583. anyhow swap is complete but i need to know if the 96 formula z harness wire colors all do the same things as the 90 617 motor wires as they are the same colors but many years different
Yellow/Black and Yellow=Voltage Regulator
Black/Yellow=Key Switch
Black, Black/Red and Black/White= CDI
Violet=Temp Sensor
also i got it all done and had spark but it was weak with 617 cdi and 583 coil. i swapped the coils and then had nothing. thinkin 617 coil posts are rusted off inside (the didn't look very good). got a new 1 on its way... ANY INFO WOULD BE APPRECIATED!!!!!!
Violet=Temp Sensor
