I just bought a 500 fomula sls from in auction. The engine came in parts due to engine failure. Clutch side crank bearings went. It also came with a used but good bottom end (crank case and crank). My question is, Should there be a spacer between the rist pin and the piston??? Thanks Jeff:dunno:
