1st: i put back together a 377 dual carb fired it up today, first i made sure there was no air leak put hand over one carb motor stalled fired up again put hand over other carb motor stalled adjusted idle it sounds like it's running right but my six sence was telling me no it's not so i pulled plugs one was hot the other was not so i touched cylinders one was hot the other was not so i switch coil wires and swithced sides with plugs and yet again one side was not firing right. switched coil wires back put in new plugs and one side is still not firing. sorry i'm not very good on what they call the side that's not firing it the cylinder beside pull start or oil pump. i'm going to check compression on that cylinder later, i replaced pistons and rings but nothing to cylinder maybe that cylinder is over sized meaning worn out
2nd: if the one cylinder was not firing why would it stall the motor when i put my hand over carb
p.s. this motor is cdi
