2013 Grass Drags get your sleds ready!
The date for the race has been set for Oct 19. Registration starts at 7:30 AM and racing begins at 10:00 AM.
There will be a racers meeting before the heats start and the order of the class runs will be posted as well.
1. Fees
a. Entrance Fee for both Spectators and Racers (12 and under free) - $5
b. Race fee - $20 per class
2. Track format – 400 ft with ample cool down area.
3. There will be a limit on access to the pits, only racers and crew.
4. Race Classes - Format (18 and older only).
a. Stock
b. Super Stock
c. Improved
d. Pro Stock
3. Validation of sleds – We have a sled tech person coming to the race and he will tech the winning sleds to verify they meet the class requirements.
4. Drag start verification and race timing – We are bringing in a professional race portatree timing system, no flag and stop watches anymore!
5. This will be a single elimination event with the opportunity for a buy in if you lose the first race. Feedback we received tells us you prefer that method over the double elimination that we have held in the past.
6. Safety - Require a kill switch tether MANDATORY!
7. Food and beverages will be available on site
8. Location of races – Broken Acres Farm – 160 Valley Rd, Jefferson, Maine
For more information about the following please go to our website for the details at the bottom of the page:
<https://sites.google.com/site/snopackers/snowmobile-races>
The planned racing order, subject to modification for operational efficiency, can be found in the document listed on the bottom of this page. Class rules stating what modifications are allowed per class are also given in a document at the bottom of the page. Finally, day of race rules are also shown in a document on the bottom of the page. Click the down arrow on the right to download each document.
Discussion Starter #2
Hello all update to the Jefferson Snopackers grass drags, main change is we are going to a single elimination format with a practice run. Please see the update info on the races!
1. Race format - Single elimination, Racers are guaranteed two runs, one practice run and one race, if you win that you keep racing. If you loose you have the opportunity to buy back in once per class. Feedback we received tells us you prefer that method over the double elimination that we have held in the past.
2. Fees:
c. Buyback fee - $10 (if you loose you can buy back in once per class)
3. Track format – 400 ft with ample cool down area.
4. There will be a limit on access to the pits, only racers and crew.
5. Race Classes - Format (18 and older only). Per class will be 500, 600, 700,800 and 1000 brackets. Need a minimum of 3 sleds per bracket for the bracket to be run, racers can move up to next class if there isn't 3 racers in the bracket.
a. Stock
b. Super Stock
c. Improved
d. Pro Stock
6. Validation of sleds – We have a sled tech person coming to the race and he will tech the winning sleds to verify they meet the class requirements.
7. Drag start verification and race timing – The Sawyers from Newport will be running the classes and timing with their portatree timing system.
8. Safety - Require a kill switch tether MANDATORY!
9. Food and beverages will be available on site
10. Location of races – Broken Acres Farm – 160 Valley Rd, Jefferson, Maine
Please download and fill out the race registration and waiver forms to save time during registration.
Registration form - https://docs.google.com/viewer?a=v&pid=sites&srcid=ZGVmYXVsdGRvbWFpbnxzbm9wYWNrZXJzfGd4OjFhNTQyOGEyYWNmZWNhYzQ
Waiver form - https://docs.google.com/viewer?a=v&pid=sites&srcid=ZGVmYXVsdGRvbWFpbnxzbm9wYWNrZXJzfGd4OjU3MmMzMzIyNTYwZDhiMmM
CLASS INFO - Same as 2012
We will have 4 Class types and in each class type there will be five engine size classes, 500, 600, 700, 800 and 1000. If in any engine size there are not enough sleds for a race then they will be bumped up to the next size class for that class type.
Trail Stock
Required:
Must have OEM (or factory designed replacement) engine, hood, frame, cowl, gas tank, carburetion,
suspension and variable speed converter
Oil injection pump must remain functional
OEM shocks must remain in place
Rear idler wheels must remain OEM
Track sprockets/drivers must remain OEM for the model
Allowed Changes:
Air box can be replaced with after market filter. Air boxes cannot be modified
Any springs or weights may be used, after market helixes are allowed
Marginal snow wheels and related hardware may be added or removed from the slide rails
After market skis are allowed
Exhaust system must be stock, complete and unaltered (Cans, Stingers are allowed)
Track changes allowed but no grass drag tracks, cutting or porting of tracks (wiper tracks)
Trail studs allowed with proper guarding, No screws
Not Allowed:
No chassis or suspension alterations (no tie down)
No component of the engine may be altered; this is to include polishing, port matching or blueprinting
No changes in engine dimensions can be made by gasket adjustments
Maximum cylinder overbore for wear cannot exceed 0.020 inches (0.5 mm)
No carb modifications
No additional fuel pumps
Super Stock:
Required:
Allowed:
Any alterations allowed in Trail Stock allowed in Super Stock
Any studs allowed with proper guarding, No screws
Tie down allowed
Wiper Track Allowed
Gearing modifications allowed
Improved Stock:
Required:
Must have OEM engine, belly pan, fuel tank and frame
Carbs and flanges must be OEM
Allowed:
Any alterations allowed in Trail Stock allowed in Improved Stock
Any alterations allowed in Super Stock allowed in Improved Stock
Any hood that maintains stock appearance is allowed
Engine modifications allowed, with no more than 1 % overbore, no strokers
Engine modifications must be done from original casting
Air box may be removed; oil pumps may be removed
Reed changes and shorty covers allowed
Commercially available, aftermarket heads allowed
Traction products allowed with proper guarding, No screws
Track modifications allowed
Not Allowed:
No pressurized fuel systems allowed
No turbos or blowers
No open pipes
No trimming of track
Pro Stock:
Required:
Must have stock belly pan and stock appearing seat, hood and tank
Must have stock appearing chassis
Allowed:
Any alterations allowed in Trail Stock, Super Stock or Improved Stock allowed
Any tracked suspension is allowed
Any Traction devices are allowed, No screws
If traction products are used, must have wrap around safety shielding
All carb changes are allowed
Maximum of 2% over cc displacement for class is allowed
If plate is used to raise cylinders, can be no more than 0.5 inch thick No super charge, turbos or pressurized
fuel systems
Head changes allowed
Strokers allowed
Any ignition allowed in 800 and 1000
Pro Stock Clutch Guard required on Pro Stock Machines
120 Mini Sled Youth:
Required:
Sled must be stock
No traction products (studs/screws etc)
For more information about the race including rules please go to our website for the details at the bottom of the page:
Just a reminder of our grass drags this Saturday Oct 19, its gonna be a great time, come on out and race if you have a sled or to watch if you don't but love racing!
