I have a 2009 polaris rmk 700cfi with the 155 track on it and a little over 3000 miles. The guy I bought it from had the engine melt down on him so he rebuilt it from bottom up putting high quality aftermarket parts in it. He also went through the clutch and clutched it for mid-mn trail riding as well as put the mesh side panel on it to help with cooling. Now the problem is that after the rebuild it has a heavy bog when you pin the throttle (sometimes will come out of it if you feather the throttle a little), when you slowly accelerate the bog will come on after about 15-20 seconds of WOT. The guy I bought it from went through a couple things, got frustrated with it, thought it was the tps and put it up for sale. Long story short I bought it for a good price thinking I could fix it for a couple hundred bucks and have a good sled with a fresh rebuild… not quite. I checked the tps, good. I cleaned the power valves and replaced the bellows (orange ones). Clutch has
10-66 weights. Replaced fuel filter (which seemed to help for a little bit). Replaced spark plugs with oem. Compression was good last time I checked it. I’m not sure where to go from here, the bog has been seeming to get worse lately and I really would like to figure this thing out. Any help is greatly appreciate! Thanks in advance for all the help!
