1 - 11 of 11 Posts
Took my GTX 550 off the trailer, last weeknd. reverse worked fine.Went to my cabin, went to reverse into my parking space, but no reverse. Any indications of where i can look for the problem?
Tried it several times but to no avail. It was just working fine and all of a sudden it stops working. im not familiar with the setup of the rer on the Bombardier snowmobiles
Does it do nothing when you hit the button or does it stall? if it does nothing than I agree with RJ that its probably the button. do you haul on an open trailer? I have been seeing lots of issues with electrical plugs and switches on these newer ski doos due to salt damage from open trailer hauling
Mine only works when you first start it up (every time!), when its cold. After it warms up, It does nothing (every time!). Either it idles too high when warm, or a sensor heats up?
Does a machine generally idle higher when warm than when cold? And the idle can be lowered by turning the screw on the carb? Sorry, I'm new at this. And what should it be at? Cold RPM? Warm RPM?
1 - 11 of 11 Posts
