I have a 2005 Polaris RMK 900 and it will only do about 35 mph and max rpm is 6250, it won't go into reverse either and when I unplug the exhaust temp sensor there is no change at all and it don't make the check engine like come on so I sure could use some help with this problem. I have checked the tps sensor, cleaned the exhaust valves and bellows, I've put a new line to the oil valve new intake boots so I'm running out of ideas
Might check fuel pressure.
