1 - 12 of 12 Posts
Hi, I have two plastic brackets broken off the hood, but are riveted to the metal hood hinges. Would anyone have any suggestions as how to repair / reattach these hinges/brackets to the hood? I've attached pictures of both sides where the bracket and hinges broke off.
65253
65254
Thank you for any info you can provide.
I epoxied angle aluminum on one sled and it held for about 2 years before it broke again. When it broke again, I re-epoxied them and also bolted through the hood. So it didn't look like I did it for that purpose, I used the bolts to hold an LED lightbar on.
  • Like
Reactions: guttersnipes
Thanks so much, that's a great idea with the light bar!
you might look into plastic welding. ? a solder iron and some of the SAME material being repaired for filler will weld up pretty strong. hinges are tough tho, lots of stress there.
I have a plastic welder and no it didn't hold up, thats why I fiberglassed it and so far it has lasted 6 years
Discussion Starter · #11 ·
Thanks again, KCCats2! I'll try going the fiberglass route. Would you have any suggestions on what fiberglass product to buy and how to apply ?
I went to Azone and got resign and hardner and cloth!
Get the area preped with like sanding disk on grinder?
Lay cloth in layers going opposite directions
1 - 12 of 12 Posts
