What would be causing the hand warmers to not work. Is it a fuse and also where are the fuses? Thank you.
Trace the wires. Since they have to go through the steering column, the most likely issue is a break or short at the steering pivot.
No fuse, either as Bear said or they just burt out!
I have found that the replacement 'Hot Grips' work great!
They come with a reducer and High and Low switch.
