Hello,
I recently purchased an 02 700 summit with a 136" track and I was wondering if i could buy stock 151" rails for the skid and just switch the other suspension components to the longer rails and have everything work properly? the guy that has the rails for sale didnt think that it would work, but i figured it douldnt hurt to ask. thank you!
Welcome!
Im not much on extensions but with Doo you will need to watch your pitch!
A 136 would be a 2.52
Get the bolt hole measurements from the original sled and make sure they match up.
Ya I would get measurements for a skid and also track. what is the depth of the lug and how much does the rear shock push the skid up would the track hit anything. Also you might want to change the chain tension considering that the track has more drag.
I spent the $55 for the 151" skid rails, I'll have to wait until I get the sled out before I can compare the locations of the suspension holes
Sent from my SM-G965U using Tapatalk
